주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Uniden phones.
258 질문 전체 보기
reapplying a broken piece from ther circuit board
Uniden Model: TCX800 handset - a capsule shaped piece (12.2M-4KU) broke off the circuit board. It looks as though it was glued on. If so, what type of glue do I use? It is obvious that I am not a student, just a mom with a broken phone.
Update
I did not see where I could edit on my original post so I've added the images here:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개:
Kelly Creech, any chance you could post a couple of images of the component as well as the logic board so we can see what you see/ Parts like this are usually not glued but surface soldered. To add images to your question, follow this guide 기존 질문에 이미지 추가하기
댓글 달기
답변 2개
Kelly Creech, that component looks like a Crystal/ Oscillator which would correspond with the "X" as reference designator. Most likely a 12.2mHz and I am sure we could locate that if needed. Right now, you can strictly solder it back. All you need is a small soldering iron some flux and solder and a bit of practice. For some decent tutorials, check here and hereas well. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Kelly,
You can totally solder that back on mama! Just make sure you don't "just try and superglue it and see what happens" --that won't work and it will mess things up for when you have to do your solder work.
jessa
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kelly Creech 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 920
