주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1505 질문 전체 보기
iPhone could not be restored. An unknown error occured (28)
iPhone 3G got wet...someone at the AT&T store put it into restore mode. When I go to restore the iPhone (per these instructions:
http://www.iclarified.com/entry/index.ph...) I get the unknown error occured (28). Any idea how to fix it? It looks like its totally bricked.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
안드로이드 수리 키트
A new screen or battery is one kit away.
지금 장보기
안드로이드 수리 키트
지금 장보기
3개의 답변
선택된 해법
Looking this up the info I find says the logic board or battery (most likely the logic board) is toast. I'm afraid you are right and its bricked but would suggest you give an Apple store a chance to look at it. Ralph
One sample of the info I found. Ralph
http://modmyi.com/forums/hardware/701981...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
가장 유용한 답변
well, ralph could be right.
but eric, i miss something in your description - there is nothing about cleaning and nothing about flashing the phone with something like irecovery.
did you disassemble and clean the phone at all???
if not - get the tools and disassemble it, clean the logic board and the connectors with ipa and a soft paintbrush, look out for odd looking stuff (white/greenish and black burnt parts)
take also care about the dock connector. a shorted nand flash could also produce errors - but that would be a little bit tougher to fix and i think you should start with the stuff i mentioned above
good luck
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I updated itunes and connecting my iphone 3g could not restore due to error (28) occured
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
erikpierson 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 13,620
