The EOS 6D was released in 2012 as Canon’s first consumer-level, full-frame DSLR. It comes pre-equipped with a 2.75”x2” LCD viewing screen, a GPS antenna and wifi connectivity.
26 질문 전체 보기
Why does my flash not work properly?
My camera has been used moderately ever since I bought it in 2012. Currently, I've been having trouble with my camera's flash and it isn't working anymore.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
Hi Jose,
There are a number of reasons why your flash might not be working.
First, make sure your flash settings are properly enabled when using the camera.
If that isn't the problem, make sure the flash connector is properly cleaned so that a good connection can be established. If there is too much dust collected, use a cotton swab to carefully clear it off.
Also make sure that your battery is charged; the flash will not fire if the battery is too low.
If none of these is the problem, your flash bulb may be burned out. Please refer to this page for help replacing it: How to replace your digital camera flash bulb
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
when I use YN560 in M mode, the bottom half picture is black. Thanks
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
That's simple. You are shooting with shutter speed faster than the x-sync speed (which is 1/180).
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Jose Urizar 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 23
전체 시간: 537
