주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Screen brightness only partly working with slider
Hello,
I replaced my iPhone5 battery and during that process something went wrong. My LCD screen wouldn't turn on anymore and it is probably completely broken. So I bought a new LCD/digitizer. I fully replaced it and my iPhone is working again.
However my screen is very dim. The backlight is working up to around 35% of the brightness slider. I can dim my screen with the slider to 0% (and make it brighter again), however above around 35% of the slider it makers no difference. Although the slider is at 80% or 100%, the LCD is still very dim like the slider is at 35%.
Someone has a suggestion on how to fix this? I already bought another LCD/digitizer but it had the same problem.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
I would troubleshoot like this:
1.) Rule out software--hard reset, then restore
2.) Rule out peripherals (sounds like you've done this) known good LCD screen/put board in a known good housing
3.) Send board out to someone like me but ideally local for backlight repair on the motherboard--replace filters, backlight ic, backlight coil
good luck!
jessa
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you for the reply jessa.
1) It's not a software problem, because I already did a full (hard) reset without improvements.
2) I will buy another LCD screen from an other store. (bought two from the same store, both same problem)
3) When above steps won't work I might go for a backlight repair and see if that solves the problem.
댓글 달기
how to resolved iphone 5 brightness light . and network problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Frank 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 730
