주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
116 질문 전체 보기
Why does the drive stop responding when connected to the USB sometimes
Sometimes the drive is not recognized after it is plugged in. Even though you can feel the disk rotating, the light does not glow nor is the drive recognized by your computer. This behaviour erratic.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Once this has happened it can cause master directory damagethat will increase problems until the drive is hosed. Use Disk Utility->repair disk for directory damage, back up your data. N.
의견 추가하세요
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
답변 3개
선택된 해법
I would suspect that the drive is not receiving enough power at times. Does this always happen at the same USB connection? If so does moving it to another USB port allow it to work properly? Of course if the drive is powered by external means I would worry the drive may be failing. Ralph
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Once this has happened you can have Master Directory damage that will cause continued problems. Use Disk Utility to repair directory damage. N.
+ agreed, different ports offer different power levels
의견 추가하세요
You may check your Energy setting for 'Put Drives to Sleep' and ensure that is off.
Update
You could have a bed drive (even if new). Look, if a company makes a million of something there is a good chance that at least one of them is bad. I have a FireWire drive that is externally powered and sometimes it just stops. I think it is the drive itself.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
The energy setting just made the difference for me. I was using this as a bootable volume for a new snow leopard computer, and the default settings for both battery and power adapter were turning off the drive whenever I tried to use it to boot. Helpful tip. Thanks.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Rakeshv79 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,276
