Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
276 질문 전체 보기
RAM - capacity and type
I have an iMac 20" / 2 GHz / 512MB RAM computer. There are 2 slots for memory boards EMC No.: 2105. Only one slot is used = 512RAM. Can I purchase an additional 512RAM board without removing my current 512MB board? Or, do I have to remove the current 512MB and purchase a 1GB ram board? Also, please advise specifically which memory board I should purchase? I'm probably not using the correct lingo. Thank you for your help...
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3개의 답변
선택된 해법
Your 20" iMac which is the the early/mid 2006 iMacs (iMac4,1). The maximum RAM for that is 2 GBs. You can mismatch the RAM sticks (1 512 and a 1 gb card)
The RAM slots support 200 pin PC2-5300 (667MHZ) DDR2 SO-DIMM
해당 답변은 도움이 되었습니까?
점수 2
댓글:
+ Ralph
의 답변
Agreed +
의 답변
의견 추가하세요
This Machine uses standart DDR2 so-dimms. You can add a second memory card of 512 mb or go straight op to 4 gigs of RAM with two 2gig cards.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Could you technically use a 1GB or 2GB stick in addition to the 512MB stick? Or does this machine require matched memory?
의 답변
I believe the max on this machine is 2GB. http://www.ramdirect.com/macs/iMacMA200L...
의 답변
의견 추가하세요
I know this question is old, but if you have an iMac 2006 EARLY (please note EARLY), there is a custom ROM that you can install that will allow you to max it out at 4GB, but only 3+ will be visible.
READ all the comments in this link before you decide you want to do this. It is not an Apple supported ROM.
http://forum.netkas.org/index.php/topic,...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
richardshelly 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,655
