주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
3006 질문 전체 보기
No audio during video playback
I have a problem with my iPhone 4s, there is no audio when playing recorded videos or via the internet, all other sound functions are fully working including voice calls on loudspeaker. Any help diagnosing the problem will be appreciated.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
의견 추가하세요
Apple Watch Kits
Screen and battery repairs just got easier.
지금 장보기
Apple Watch Kits
지금 장보기
6개의 답변
가장 유용한 답변
Hey there, if you usually pair your iPhone with any bluetooth audio devices, try turning bluetooth off and seeing if this fixes the problem.
this sometimes happens with me when the iphone thinks its still connected to my bluetooth car stereo.
hope this helps
Chris
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Is Speaker function working on calls? if not, the speaker is damaged- probably needs replacement, or as in my case starts working on its own after couple of days :)
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Change the dock connector it works fine for me I had the same issue as you discribe.
You can try cleaning the dock maybe there is some dirty or dust I the dock. Take a small part and pull out if something is inside and try again.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thanks for your help.
의 답변
의견 추가하세요
I am having the same problem. But no answers have offered a solution to my phone yet.
I just want it to play via headphones, no sound on video. Everything else works 100% fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
You tried a new dock connector?
의 답변
의견 추가하세요
The "change with buttons" option causes this. Check this box in settings. That fixed it.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I have an issue when I use my iPhone to video record something. The recorded video picture is there but no sound. I can watch a YouTube video and it's OK. It's just when I use the video recorder.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Can I re-install the video recording separately or use a different program?
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
S2i 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 75
전체 시간: 37,604
