What logic board can I buy?
Hii, i've got a problem with my SATA controller so i need to change my logic board. I found a A1286 on ebay but does it work with my computer ? Ifixit propose for my computer A1278...
좋은 질문 입니까?
좋은 질문 입니까?
The designation A1278 is practically useless it pertains to 12 different 13" machines from 09 to 012. As Oldturkey03 pointed out you need to provide a more specific identifier of your machine and the board - if it's not an 09 board it will not work in your case..
Due to case and display changes (ports and screw holes) you generally can not cross model years but you can go from a base logic board to a custom higher speed machine... e.g. in the 09's a 2.4GHz board would fit in a 2.0 machines case.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 144
댓글 5개
Quentin Lemonnier, what is your computers serial number? That will help us to properly identify your existing logic board and possibly find a right substitute. You are usually ok if you stay within the same series, same year.
oldturkey03 의
Thanks, ed6022b7-27e3-591a-a695-d1d15f141dea
Quentin Lemonnier 의
does not look like a valid
serial number
oldturkey03 의
Is it better : W89423AV66J ?
Quentin Lemonnier 의
2.53 GHz Core 2 Duo (P8700)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MB991LL/A Model No: A1278 (EMC 2326*)
Subfamily: Mid-2009 13" Model ID: MacBookPro5,5
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
oldturkey03 의
