주요 콘텐츠로 건너뛰기
Repair guides and support for Kenmore washing machines.
Kenmore 110 Washer won't drain or spin? solved
I was doing laundry and machine was working perfectly until it got to a point where water gets drained.. no any kind of sound or noise that it's even trying to do anything, water just sits there in a washer.. Any suggestions what is happening with it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Is the load balanced? Is the drain hose clear and unclogged and unkinked?
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Yes it was a lid switch issue.. it's fixed now! Thank you!
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 890
