주요 콘텐츠로 건너뛰기
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
28 질문 전체 보기
질문 마감됨
Charging problem ipad mini
When i connect my charger connector to my ipad for charging i cant get answer because it shows not charging what should i do please help me
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
What is the history of this device? Is it actually not charging, or just saying it is not charging? i.e. What happens if you use the device until the battery is dead and then put it on the charger?
If the iPad has been opened, you may have damage at the battery connector (common) otherwise, the most likley problem is a failure of the dock connector which you can replace--although it does require soldering. You may want to send this part of your repair out unless you have experience soldering.
jessa
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 799
