주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Bottom of iPhone doesn't work after screen replacement?
So I replaced the LCD screen and when I was done and tested a few things, I found:
-audio speakers don't let out sound
-iPhone doesn't charge when plugged in and iTunes doesn't detect it
-the home button doesn't work
I realized that all the problems were located at the bottom of the iPhone. Is there any way I can fix these problems?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
All these problems relate to the dock connecter not being plugged in correctly.
Open up when and reseed dock connecter as it sounds as if it's not plugged in
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
It worked!!!! Now everything works perfectly!!! Thank you soooooo much!! :D
Your welcome
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 276
