메인 콘텐츠로 스킵하기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2997 질문 전체 보기
iPhone 4s earpiece not working tried replacing
Hi, I have experienced this a few times, I had a phone come in and the earpiece does not work, I changed the proximity sensor as the power button didnt work either and also changed the earpiece but that still does not work, what else apart from the earpiece and the contact strips on the board can prevent the earpiece from working? Thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
2개의 답변
선택된 해법
Sounds like you have a bad audio chip, almost impossible to fix, sorry, if you had a 4 instead of a 4S I would have an easy fix, the only other option would be that the headphone jack is dirty or has failed and is stuck on headphone mode so all audio is being sent there when on a call, try this make a call take the phone away from your ear watch the screen, turn volume up and down while on call and see if the volume on the screen says (heaphones) while your adjusting volume if it does than you need to clean or replace the headphone jack, good luck.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Well the earpiece is only stuck to the proximty power cable so either u have damaged the cable or it's not plugged in correctly..
And make sure u have the earpeice installed the correct way with the gold prongs pointing toward the top of the phone
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Hi, thanks for your reply, I know the earpiece is only stuck to the prox I was just explaining that got changed also. Yes the gold prongs are facing towards the top of the phone, I have tried 4 new earpiece and still not working, I am wondering if there is anything else that can stop the earpiece from functioning?
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Kbobble 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 1,229
