주요 콘텐츠로 건너뛰기
PS4 컨트롤러 모델 CUH-ZCT1. 소니 컴퓨터 엔터테인먼트에서 2013년 11월에 출시한 이 6축 3.7V 리튬 이온 배터리 컨트롤러 수리는 복잡하지 않습니다. (참고: 해체 안내서는 이 모델용이 아닙니다.)
20 질문 전체 보기
Face buttons are loose
I recently replaced my joysticks because they were wearing out and everything works great. The only issue I have is that now my face buttons seem to be a little loose. When I shake the controller I can hear and fell them wiggle around. Is there a screw that needs to be tightened or any other fix?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
This isn't a particularly good answer, as I haven't had the chance to open a DS4 yet, but I can almost guarantee that something fell out or was misplaced when you replaced your joysticks, typically a lot of components are sitting loose in the enclosure, especially face buttons. If you don't get an answer that's a bit more helpful, try opening the controller in question as well as another controller that hasn't been opened, see if there's any discrepancies. Just make sure to keep the front of the controller facing down so none of the buttons or anything fall out, I think that's mentioned in the joystick replacement guide as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I was watching the Ben Heck show on YouTube. He made a handheld game system and the buttons were loose, so he put funky foam around the buttons to hold them in place. I know that most controllers use membrane buttons, and his system used tact switches, so it may not work as well, but it's a relatively low-risk repair idea.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Collin W 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 2,320
