메인 콘텐츠로 스킵하기
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
799 질문 전체 보기
What's going on with the display on Toshiba Satellite A205-S4629?
Laptop will only boot when the AC adapter is disconnected, and then, the display will not display any characters, only a blank screen (but back lit). Once the system starts to boot, however, you can plug the AC adapter back in and it will continue to boot. With the screen being blank, I cannot tell what is actually taking place. All I get is drive activity for about 5 minutes or so, and then some type of musical alert (probably asking me for some type of response). I can't tell what type of response is necessary because I get nothing on the screen. I don't have an external monitor to plug into the VGA port to tell if the on-board video is bad or just the display. Any ideas on how to proceed?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
3개의 답변
선택된 해법
Correct on question one. Lights will flash briefly, hard drive light will
flash for a moment, then nothing. Unplug the AC adapter and turn it on,
then the display backlight will come on (nothing displayed, though), then
all kinds of drive activity for about five minutes. After about a minute or
so, you can plug the AC adapter back in and drive activity will continue.
At the end of the 5 or so minutes, there is an audio prompt that something
has happened or been completed. I just can't see anything on the screen to
tell me what that something is. The machine will remain on until you either
hold the power button to turn it off or the battery dies. No broken hinges,
cracks or signs of stress. As for the battery, it is bad. Will only hold
about a 20 - 25 minute charge and then the system dies.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
This is what I have done in a similar situation. When you start to boot your computer as soon as you push the power button, start rapidly pushing F2. (the same way you press F8 to log into safe mode). Your computer should start doing self testing. can let that run are you can push esc. Then you'll have. F 1 through 4 to run diagnostic test. if it doesn't boot into that mode. if you have a rescue disk, I even used fix utilities 10 or 11 rescue disk. I will have to do some experimenting because I don't remember which F key you continually push to open it in the boot mode. I think it is F-10 (yes F 10 is correct) then you can change the boot order and have your cd-rom boot first after you change the boot order as soon as you turn it back on open ur CD ROM and put your rescue disk in and set the CD ROM and it should take off from there. then just follow the directions of the rescue disk. then you may have to F10 again. then once back in push F9 it to setup your defaults then then press f10 for save and exit. I hope that helps you to figure out. Keep me posted, we will get it figured out.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I managed to get hold of an external monitor and plugged that in. I was able to get video this way and can now access the system to glean the information I need. I'm guessing that the ribbon cable connecting the laptop's display to the main board is damaged or else I wouldn't be able to get video with an external monitor. The AC adapter issue I haven't been able to figure out as yet. I still have to boot the laptop without the AC adapter connected, then wait about a minute or two before I can plug the AC adapter back in. If I do things that way, I can get a successful boot. I'm debating if I want to send the laptop in to have the display issue fixed, or just use an external drive and something like Norton Ghost to either image the entire drive, or just grab my personal stuff off it and then trash it for a new machine. It's probably not worth the effort to fix the display as it will most likely cost more to fix than the system is worth. Of course, I can always just buy a cheap monitor for it and use it as a secondary desktop system, thus getting as much use out of it as possible before it finally gets trashed.
Thanks for the input, though.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
George Fliger 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 736
