주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2191 질문 전체 보기
질문 마감됨
black display after reparation of the power button
Hi, I had a problem with the powerbutton on my iPhone 4S. I bought a new flex calble for the power button and followed your instructions. Everything was ok but when I wanted to start the iPhone I only got a black display. The button works - I feel the "klick" - and there is power on the battery. You can feel the engine start but I have a black display.
Are there any typical mistakes which can occour by following the guide and are there any solutions?
With kind regards
Martin
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Just make sure the connectors are seeded correctly.
As so plug into computer and make sure ITunes reconises it .
If it reconises it and still black screen and connectors ok then it's a damaged display
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
well my display was absolutely fine before I did the repair. My itunes recognieses the iphone without any problems. The connectors are on the right position. is it possible that they are polluted? And how could I solve it? Tanks in advance!
댓글 달기
Try Reset, hold both home and power buttons for about 10 seconds until the iPhone begins to restart itself.
As con said, make sure the LCD Display flex is perfectly connected to logic board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
well the screen becomes lighter at the edges when I press the home button but there is no nromal screen. Is it possible that the connectors are polluted?
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 68
