주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
4098 질문 전체 보기
No sound during calls . FaceTime/music/mic works - Repair motherboard?
Hi,
I got a really weird problem with my phone. Ive browsed the internet and really haven't found any information regarding this issue.
As the topic states..
Troubleshooting
- Mic works, tested it by recording something.
- Tested both speakers, working.
- Re-installed several times.
- Got all bars on 3G/4G
Issue
- Upon calls i can't hear anything, same goes for the other party. No sound at all.
The weirdest thing is tho, if i use the keypad and press any given key, like 1,2,3,4 it will be heard in the other end.
But apart from that, no sound at all.
- FaceTime works, no issue when making calls with that.
Sidenotes
- The unit was dropped, cracked display. Replaced the display and got this issue.
- All cables and parts are correctly mounted.
I reckon this aint a software issue anymore, more likely to be hardware. Does anyone know how to repair this? Guess its motherboard related.
Lots of thanks in advance!
Love the site and keep the good work up.
//L.Wac
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 4개
가장 유용한 답변
I've got the same thing
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
If both ear speaker and mic stopped working at the same time it's most likely the audio ic chip that's faulty same thing always happened the iPhone 4
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
On a iphone 4 model I've recently heard that you don't get audio but there must be a download software app or something to help solve this
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
When u use a iphone 4 model to facetime other compatible device above a 4 or 4s + you can see the other person only and hear them but they won't hear you hope this helps answer your questions try look internet for audio app for FaceTime and try update your phone in settings
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Xem 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 10
전체 시간: 5,871
