I just went through this. Took it to Apple Store genius they did all their tests and found that the hard drive was inoperable.
They would not put a new hard drive in because I had taken it to an authorized Apple repair person and they had replaced the hard drive with a non-apple hard drive.
They had me go to Best Buy and sent instructions for the geek squad to replace the hard drive with a 2.5" SATA drive. I then took my MacBook Pro back to Apple and they placed my operating system in at no charge (apparently apple must send the hard drives they replace back to the apple company for evaluation) since repair person put something else in about 15 months ago that was not the same as the original Apple would not replace it under terms of my apple protection plan).
Lesson learned! Even though it was an authorized Apple repair shop make sure it follows the Apple protection plan and also records the repair work done where apple genius can access it. I went to authorized Apple repair shop because the nearest Apple Store was 100 miles away.
I hope this helps!
19 댓글
pr7malone, "the LVDS cable end that plugs into the Logic board looks messed up at the connection." How about posting a couple of pictures and let us see what you see. It is entirely possible that this is your issue.
oldturkey03 의
I tried everything, all of the above and then some. I happened to find someone saying "just enter your password on the black screen". Wow! It worked. I'm on a MacBook Pro 2015 running OS Sierra.
spinaddj 의
Awesome guys , I tried reloading operating OSX (at Apple support suggestion) and various system and hardware resets,shift-option-control-power, command-option-p-r.
I was on the phone to Apple support waiting then I came across this (type in your password and hit enter)
and it worked . Many thanks for posting spinaddj
Macbook pro 2011 OSX Sierra sorry MacOS Sierra
Qadrati InFlo 의
I tried EVERY hack I could find online. Nothing worked. Then I stumbled on this page and saw the simple suggestion to enter my password again. Voila! You guys saved my life!!
Ash 의
Ash, what device and version of software are you using? Mine still does it (goes black) when the batt goes flat and I reboot but the password trick still works.
Qadrati InFlo 의
14에 댓글 더 나타내기
