I see a charging symbol, but the battery percentage is not increasing.
My iPhone 5 was working properly for more than 1.5 years. Now, I'm having a few problems with it. I will explain the problems one by one, after doing all the diagnosis I can on my end:
- When I charge my iPhone, it shows the battery percentage indicator, but the battery percentage doesn't increase.
- The charge indicator will stick on the number that's currently on the display.
- After restarting the phone, I see the battery percentage increase—but this doesn't work every time.
- Sometimes the phone charges properly, but I have to face this issue most of the time.
- When I do a hard reset (home+power button), the battery percentage drops from around 25% to only 8%.
- When I try to connect my phone to my PC, the phone restarts again and again.
- Sometimes, when I use my phone while charging, the battery percentage will not increase.
- When I charge my phone with the battery below 10%, the phone restarts again and again.
- Sometimes, when the battery is totally dead and I try to charge it, the phone won't start, and it will only show the red indicator on the screen.
- I've been facing this issue for the past week. My phone is currently on iOS 7.1.1.
- When the phone gets to 100% charge, it does not show the full charge indicator on the battery.
- I need to unplug and connect a few times to make the iPhone connect to iTunes, but iTunes works fine on the phone.
- The phone has never been repaired before.
- I've tried changing the charger and cables. I've also recalibrated the battery and performed a restore, but that didn't fix the problem.
Is this issue due to a bad battery, or is there some problem with the phone's logic board?
좋은 질문 입니까?
댓글 72개
Mine does the same thing but I have a wall plug that lights up when my phone is charging so if I plug my phone in and it doesn't light up I can usually shake my phone a little and then it will light up but today I can no longer get my plug to light up so now I don't have a clue if my phone is really charging or not
Bethany 의
Omg my battery says it's charging but it's already 100%. I know it is but it keeps saying it's only 99%. I really need help.
Cindy 의
UPDATE TO MY LAST COMMENT:
It SOMETIMES charges to 100% and sometimes it doesn't. I mean, it's fine by me because some people have a problem that it doesn't charge anymore so if it is dead then it will never be able to work again. I'm just happy it can charge.
Cindy 의
i have iphone 4s, when i was update my phone ios 8, after this my phone is not charge properly, bacttery backup is very less, battery charge up to 65% only. please suggest what i can do for this. please help me.
rohith 의
My iPhone 5c won't charge properly it'll show the charging thingy on the screen but won't turn on. And when it does turn on it'll go from 8% to 1% and die instantly and it will keep doing this for hours. Then when it does charge properly the battery dies really fast. Help?
beth williams 의
댓글 67개 더보기
