주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Gyroscope stopped working, no screen rotating, after rear case replace
Hello there.
For starters. I have an iPhone 5. I've replaced the power button on my iPhone, after that everything worked just fine - normally I have the standing position (portrait) locked, so the screen doesn't tilt when I'm laying in my bed. But then I found and old game that I used to play, this game is called Labyrinth, it's a game where a ball is moving the way you're tilting your phone.
But the ball stood still, I've tried to reset the phone back to factory - but it when work. I've tried to unlock the lock, so that I could tilt the screen into landscape mode, this doesn't work either.
I've tried to search for answers and I come up almost empty handed. The only thing I found out, is that sensor (gyro?) which picks up that the phone is tilting are located at the Logic Board.
I don't know when the sensor broke. Because I don't use it very much. I've read that it often comes because of you dropping your iPhone on the ground?
I came aware of the flaw after home button replacement.
The problem is that the tread was old and no one answered my question, which I'm now asking you:
- What can I try to make it work?
- Is there any cable of something I should try to take off an set it right back?
- What can I do to troubleshoot this?
- Is it possible to change that censor, on the Logic Board?
The only question is: What can I do to fix this?
Hope someone out there can help me!
Best,
Stefan
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hello,
I don't believe that you problem is a sensor. The problem sounds like the mute/ rotation switch is broken or may have been installed improperly. Do you have it set to mute or to lock rotation?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have this same problem. My iPhone 5s cannot play games with tilt controls, including VR. It absolutely sucks because I used to love using my VR headset and playing Temple Run 2 but now I can't
댓글 달기
귀하의 답변을 추가하세요
Stefan Bols 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 6,799
