주요 콘텐츠로 건너뛰기
많은 브랜드의 PC 랩탑 (노트북) 컴퓨터 수리 안내서.
18861 질문 전체 보기
How to remove stuck SD card out of laptop's card reader?
Hi everyone!
A while ago I inserted the dummy card in my laptop's card reader slot, but it got stuck. Any ideas how to get it out the slot, so I am able to use the slot?
Thanks!
Andrew
Update
I have tried it several times, but I am not able to get the needle to the end, because there is not enough space. Even with a second pin I am not able to get it out of the cardreader. On the other side are the contact pins and my needle gets stuck there.
Should I use a hobbytool to drill the dummy to pieces? I am affraid that's the best option...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 7개
선택된 답변
Get a fine sewing pin and put a little hook on the end (about 2mm hook) get the hook in behind the card and gently tug. You may have to use a second pin without hook to guide the card up or down.
해당 답변은 도움이 되었습니까?
점수 3
댓글 5개:
I used sewing needle to pry it out--picking at it from the front on the sides and bottom. (It's made of soft plastic and I don't mind if I damage it.) Eventually it came out. YEA!
Thank you! Thank you! Thank you! Thank you!
I uses a very thin sharp knife slid it in the top of the card. Then I wiggled it from side to side. The right side then came out a little more eventuall wiggling it side to side and the left side released. I put it back in and had same problem so I threw the card out and new one worked fine. I believe it was catching on sides not top or bottom.
I used a fine needle without a hook and just tried to wedge it out a little at a time - worked - but you need to make sure it isn't in the lock position - if it doesn't move maybe locked so push it in again :)
Thanks. I used a fishing hook to remove the SD card. It came out perfectly.
댓글 달기
가장 유용한 답변
I got a small piece of packing tape (other tape would probably also work) and inserted it next to my SD card. I kind of pressed it a bit against the SD card and was able to pull it out.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
this was the same as a youtube video on how to remove a memory card. what a savour, me knowing it works for SD's too is good
댓글 달기
take some tweezers and pull it out of the card reader thats how I got mine out
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
It didn't work!
Just damaged the SD card
댓글 달기
A thin pointed knife and 1 chopstick on each side - ejected in less than 30 seconds.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Get some pliers and pull it out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Using a sewing pin, push pin, or another thin needle-like tool: Insert gently on each side of the SD card stuck in the slot. Slowly “wedge” out the SD card with just one of the needles until a corner of the SD card is accessible with a pair of tweezers.
Alternatively, if the above method does not work, there is a method that my 12 year old son thought of (my kid is freakin’ smart!).
Get a Post-It note and cut it in 2 small strips the width of the SD card. Be careful not to touch the sticky portion during the process (so you don’t ruin the adhesive). Slip each strip above and below the SD card, making sure the sticky portion is facing the SD card. Slightly and gently turn the strips left and right 30 degrees to ensure the strips stick to the surface of the SD card. Wait a few minutes for the adhesive to completely adhere, then pull it out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
The needle method worked great for me once and have saved me again! I took a hot glue stick and some matches and stupidly decided to use this method and oh boy, oh boy, did i &&^& up. After clearing the two sides of the sd card slot i inserted the needles and used them like chopsticks and it worked
댓글 달기
My memory card is stuck inside the spring system, I can secure tweezers around it but it’s still stuck inside and I don’t know how to take it out, I’d need a ton of leverage or maybe even to take apart the computer to get it out. Any better recommendations?
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
get tape and push gently but firmly on the sd card with the tape and pull towards you
btw pust the tape down on the card
PUSH i meant stupid me
댓글 달기
귀하의 답변을 추가하세요
Z3pcs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 15
7일 전: 108
30일 전: 506
전체 시간: 61,658
