주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Laptop won't turn on after creating a spark
Hi Ifixit,
First time I've had to post about a computer problem I've been having. I was trying to clean my fan when I did something really dumb and used a metal tool to try to take the battery connector off the logic board. It slipped and I touched one of the soldered pin above it. There was a small orange spark, but that's it. When plugged in, the green charging light comes on, but nothing on the laptop turns on. Everything's connected fine and there doesn't seem to be any damaged wires or anything. I honestly don't know much about Macs or the innards of laptops in general, so please bare with me. If anyone needs any more information please feel free to ask. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
Try taking your battery out and removing the bios battery from the board (not using anything metal lol) also make sure the power cable isn't connected either. Once you have this done press the power button a couple times holding it in for about five seconds roughly. Put the batteries back in plug your power cord in and try turning it on. This may or may not work but what it should hopefully do is remove all power from the capacitors and computer it self and if there was protection built into the chip hopefully it should cause the chip the shutdown and reset. No promises that this will work but once in a while it does help. Let us know what happens.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
what if it is built-in battery ??
댓글 달기
귀하의 답변을 추가하세요
Alex Chau 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 17
전체 시간: 3,880
