The Microsoft Surface RT (model 1516) is the first tablet released by Microsoft. It runs Windows RT, which is designed specifically for tablet functionality. Repairs for this device require screwdrivers and prying tools.
71 질문 전체 보기
Where do I repair my broken screen
the screen of my Microsoft Surface tablet is broken where do i get a new screen?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
Ebay. I bought one there for my Surface RT and it works like a charm.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
My touch screen is also unresponsive with a small crack. Do you know which part I need to buy? I'm seeing on ebay, lcd digitizer replacement screens for as low as $50. Would those be okay to buy? Or do I need to get the lcd touch screen digitizer assembly? I've seen those on ebay for around $100-150
의 답변
@abigail
Yep mine was the same problem.
The problem with buying just the digitizer, is that in the tablet; the digitizer (the part of the screen that you touch) and the actual LCD panel are fused together. it's virtually impossible to separate them.
You can try to separate them, I did and cracked the lcd, but I think you will find that its just not worth it.
I would recommend that you buy the LCD touch screen digitizer ASSEMBLY.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Rishika Manik 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 3,044
