Remove stuck broken stylus from headphone jack?
need help in removing the piece from my phone don't know what to do help
좋은 질문 입니까?
좋은 질문 입니까?
Hi, if it's a piece of broken headphone jack plug that's stuck in there then I have been able to remove them in the past using a 3mm screw about 20mm long.
Dab a small amount of super glue to the end of the screw, make sure you just get it on the end and not on the sides of the screw and put it in the headphone socket and leave it to dry for about 1/2 hour.
Carefully pull the screw out and whatever is stuck in the socket should now hopefully be on the end of your screw. Sometimes it takes a couple of attempts but have successfully used this method a few times now.
해당 답변은 도움이 되었습니까?
You are a genius
I have that problem with a DAT machine but the superglue method didn't work. Any other solutions?
해당 답변은 도움이 되었습니까?
Using a power drill with the smallest diameter drill bit (about size of a pin), drill a very light hole into the stuck piece of stylus. Using a small sharp tipped wood screw, hand screw it with screwdriver into the drilled hole just until you feel it start to grab. Hand pull out the screw with the stuck piece of stylus attached. That’s what worked for me.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,237
