broken wires are *above* the control box?
What if the broken wires are *above* the control box??
좋은 질문 입니까?
좋은 질문 입니까?
Nomi Windhorn, all you have to do is open the control box, unsolder the broken wire. Then cut the wire that is broken above the control box, strip it and solder it to the control box. Hope this helps, good luck.
To open the control box
turn it over
remove the three screws and remove the cover
now you have access to the cable. Unsolder the old one and resolder the new cable. check the color code for the cable
해당 답변은 도움이 되었습니까?
I was also dealing with the same problem fantastic answer oldturkey03 I've successfully repaired the wires thank's a lot man.
James From--- http://www.westcables.com/
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,053
