주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
296 질문 전체 보기
The smart case is locking the iPad when it touches the back?
I completed an iPad digitiser replacement, the smart case now locks the device when placed on top of the device, as normal. However, it also locks when folded behind and contacts the rear. I've opened up the iPad again, but I can't identify the magnets or find a solution.
I also can't find anyone else with this issue, any help would be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 6개
선택된 답변
You smart case magnets are probobly to strong I would just turn the feature off on the iPad
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks for this. Not quite perfect, but it'll do.
Turning it off is NOT a valid solution. Smh
댓글 달기
Same problem here: after a replacement the cover turns off the iPad from the back, not on the front
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Same thing happens to me. I thought maybe I pinched the ribbon cables. But without that case it all,works fine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This happens when you don't use a genuine home button, it locks when the smart case is on back or front. Add the original or genuine home button (the ones that come with replacement air screens tend to be copies) and the problem will go away
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I was in class and then my iPad Air just attached to the desk and the desk is metal and there is a magnet I think in the iPad and the iPad just attraks and it’s just the sid across the camera
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have an original Apple Smart Case and never experienced this.
Than i cracked my screen and went for a replacement.
Now I have ghost touches and this magnet thing.
The question I have is the guy changed the digitizer glass so what can he have moved to do this?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
transbaconist 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 2,292
