13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
614 질문 전체 보기
Airport Icon not showing up. No Airport card error
Macbook 13" A1278 Mid 2008
I have a late 2008 macbook unibody aluminum and it would not let me connect to wifi because arport was not an option. I bought a new airport card and installed it but even after that there still is no option for airport in network settings. Please help.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
5개의 답변
선택된 해법
Look under the Apple in the upper left hand corner to "about this Mac". Go down to the wi-fi and see if your machine sees the card.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
This is what it says i don't think it sees it. (Picture is below)
의 답변
의견 추가하세요
가장 유용한 답변
First, click the + icon in network settings. Choose airport/wifi for the interface. Click create, then click apply. If that doesn't work, check the cable connections. If that doesn't help, replace the logic board.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
i would have tried that but it doesn't even show up it only has ethernet, bluetooth dun and pan and ppoe and vpn and some other thing i dont know about.
의 답변
and replacing logic board wont help as the airport card is completely separate from logic board. The weird thing is that the camara and bluetooth both work. Which share the same cable connecting the single wifi/bluetooth card
의 답변
Hit the add button (+) and add the wi-fi to the list of options.
의 답변
i already tried that no option for wifi show up
의 답변
의견 추가하세요
Well it took a little while but i figured it out. It turns out the logic board connector had bent pins so i carefully bent them back into place and wifi works flawlessly now thanks for both of your answers.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
of which connector you talking about? I have the same problem
thanks
의 답변
의견 추가하세요
See image content:
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Had the same problem Valiera .. with all the same symptoms and attempts ...
... a difference is a screw on the vent is shredded! I can't take the vent off and because of that can't remove the airport card! I hadn't checked the logic board pins, will try that next.
Thanks for your thread it lead to something new.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Valiera 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 57
지난 30일: 218
전체 시간: 5,209
