주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
Technique to fix "soft" topcase buttons?
Hi All!
In my travels repairing A1181s, I've come across dozens of topcases with "soft" buttons -- buttons that do not "click" on the left side, and pressing on the left side does not register. This issue can often be relieved somewhat by pressing up from the underside of the button in various places, but this only works with varying degrees of success, and often I'm left with a topcase that works otherwise, but that I can't use because of this problem. I've also soaked the button in alcohol, which can "un-gunk" the situation and sometimes helps, but again it's not a universal solution.
Anyone have any other techniques to try? Unfortunately the mechanism is sealed up, so there's not an ability get in there and mess with it.
Thanks,
John
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 1개
선택된 답변
Dear Road Kill, this Apple guide has helped me on a couple of boards and may give you some ideas that you might not have thought of. Then again, it may not:
http://support.apple.com/kb/TS1381
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
rdklinc 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 320
