주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3417 질문 전체 보기
Torn Front-Facing Camera Ribbon Cable causing screen artifacts?
I opened my phone earlier today to check for a loose power cable connection (the power button hadn't been working right since I replaced my battery) but opened it too quickly and tore the front-facing camera and sensor ribbon cable. Somehow, I didn't tear any of the other 2 connectors that connect the screen to the main assembly of the phone.
I figured it would be a quick fix, I just need to order another cable and then open up the phone, but when I tried turning on the phone to make sure nothing else had been damaged, it wouldn't boot. Instead I was met with these strange screen artifacts and nothing else.
I'm assuming the issue is still with that single cable (perhaps it being detached tripped some kind of pre-boot test in the phone and so it refused to boot), but I wanted to make sure I didn't need to order anything else. Could something else be wrong with the phone that's causing these artifacts, or is it just the detached front-facing camera and sensor?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 1개
Those boxes are usually indicative of a bad connection to the LCD. Where the bad connection is would be anyone's guess. The cable could have been strained where it attaches to the LCD, or it could have been bent, folded, stretched along it's length. It could also be the connector on the ribbon side, the connector on the logic board side or simply both of them where they meet. You may want to replace the LCD to get new cabling. If that doesn't fix it you are likely going to be dealing with logic board damage.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
kurplenk 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,065
