주요 콘텐츠로 건너뛰기
The Samsung Brightside features a 3.1-inch touch screen and slide-out QWERTY keyboard.
21 질문 전체 보기
There is a dark spot in my lcd after it got wet?
My Samsung Brightside went into the lake with me and got all wet. Now I have a dark spot and a bright spot in my LCD. Do I need a new LCD?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Brian, very possible that you have some sort of residue on your LCD. Yes, best is to replace it, as well as replace the battery and clean your logic board with plenty of isopropyl alcohol. Otherwise, you are running the risk of having failure due to corrosion at a later time. Here is the guide for that. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Brian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 148
