주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Front camera blurred. Freezes. Resistor value. SOLVED!
Hi.
Since i had to disconnect and reconnect the front screen several times, i unfortunately broke one of the resistors of the logic board.
Does anyone have the schematics for an iPhone 5, so i can get the correct resistor value. Thank you.
Okay. I solved this one. Just solder the two points... simply short circuit. Is works.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
Can u shows the picture of the soldered place?
See the red circle on the attached picture in post #1. Beware that the footprint is very small. You will need some kepton tape or a steady hand to do this :)
댓글 달기
답변 2개
선택된 답변
No--it's FL14 a data filter. If it were a capacitor he'd have shorted out his phone by bridging it!
Knocking off FL14 will break the continuity in the camera line, so although replacing it with another one is ideal, bridging the filter pads like you've done will restore continuity in the line.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Correct, it's a filter. I didn't have the component, and it is not easy to solder since it is a 01005 housing. So I short circuit it. Works fine.
Hi jessabethany.
I believe i have this problem too.
In my case the one that was accidently knocked off is FL15.
Is it safe if i could just put the jumper in there?
my motherboard is like that picture but the schematic diagram in not tha same its only one coil and one capacitor i can't understand what's wrong why they are not the same ?!
댓글 달기
가장 유용한 답변
This is the information from the schematic, C192 56PF 5% 2 6.3V NP0-C0G 01005
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
My own at the moment is the back light. The screen is dark but phone work. What if i bridge or just circuit? I need to restore backlight.
댓글 달기
귀하의 답변을 추가하세요
Klaus M 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 5,705
