Replaced AC compressor, worked briefly, now non-functional
The AC in my 2005 Mazda 3 stopped working 6 months ago. Finally got around to working on it: replaced the high pressure hose, then realized the compressor had seized. Just finished putting the new compressor in.
I cleaned the system with solvent and put it under -30psi vacuum for ~an hour. Then charged it up, and it worked great! For about ten minutes. Then the AC started fluctuating in temperature from room temp to cold. Then I got a burning smell and it stopped cooling.
The AC clutch is not engaging now. The low side of the ac was at 50psi when I charged it, and it's at ~150psi now (but the car is hot).
Any ideas? I'm thinking it might be a stuck expansion valve. There was a bit of metal in the oil from the old compressor.
Update: My friend posted a request over here and some mechanics have replied with a few ideas. I'm going to order a new condenser, dryer, and expansion valve next.
좋은 질문 입니까?
Kyle, just to make sure, you did check the fuses and the A/C relay to make sure those are working? Also, you checked the voltage on your clutch? DESCRIPTION • Magnetic clutch does not operate.
• Malfunction in PCM AlC cut control system
• Malfunction in climate control unit
• Malfunction in refrigerant pressure sensor
• Malfunction in PCM (AiC signal)
• Malfunction in PCM (IG1 signal)
POSSIBLE • Malfunction in AlC compressor
CAUSE • Malfunction in AlC relay
• Malfunction in evaporator temperature sensor
• Malfunction in BCM
• Malfunction in instrument cluster
• Malfunction in CAN communication
• Improper refrigerant charging amount
oldturkey03 의
