주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
402 질문 전체 보기
MacBook won't turn on, no sound, no screen and no fans blowing
Dear people,
I charged my MacBook last week on work and the next day it wouldnt turn on. Wen I press the on/off button literally nothing happens..
I've tried multiple chargers, power sockets and even left it in the charger overnight. I've left it off for a couple of nights then tried to charge it but it didn't matter.
Some info:
The battery indicator on the side of the macbook doesn't show any green lights when pressed.
The little green light on the MagSafe charger burns BUT very dim, I almost couldn't see it but I just noticed because it was dark in my room..
I was cut out from power at home because we just moved in so there was no electricity. I didn't know that and plugged the charger in the wall anyway. The macbook was turned of at that moment but it didn't turn on after that.
How can I find out what the faulty part is, could it be the battery or could it be more serious like I short-circuited the logicboard.
Is it safe to remove the battery and check if it works without battery but a plugged in charger?
Please MacGods, save me and give me every suggestion you got.
Many thanks and have a good day
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
The very first thing to do is to drop in a new battery. This should at least give us a better idea of what's going on. Of course, that may be all it needs.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
I'll get a battery soon, kind of worried that it might not be the answer and that I'll be "wasting" money.
I Replaced The battery with a working one. Still nothing happens and nothing changed. Any ideas left?
With no symptoms, there's just not much to go on. If it was on my bench, I'd try a known good mag-safe adapter and see if there were any changes.
댓글 달기
Hello I had the same problem with a macbook pro 17" unibody, I found this and it worked.
http://forums.macrumors.com/showthread.p...
Good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Danny Riem 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 25
전체 시간: 6,486
