주요 콘텐츠로 건너뛰기
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying.
957 질문 전체 보기
Why are some pixels on my iPad the wrong colors?
The digitizer for my iPad is probably messed, because a lot of the pixels are different colors from what they should be. My iPad screen is cracked, but this did not happen due to that. This has happened before a few times, when I had it loose in a bag or something. All I did was turn it off then back on a few times, and it was fixed, but this time it isn't working. I even tried to restore it, but that didn't work. Is there anyway I can fix this myself, because I need my iPad, but I really don't have the money.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
3개의 답변
Don't bring funny but hit it a good smack on the rear see does it cure this if not then the lcd is messed up and needs a new1
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Even though you said "don't bring funny", I thought this was the biggest joke ever, but I realized 'I really have nothing to lose', so I tried it 2-3 times, and it worked. I just want to thank you so much.
의 답변
의견 추가하세요
Lol. Think I was ment to write not being funny
But I'm so happy it worked for you
Mark as accepted answer will help people out
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I don't get it what you mean by "hit it a good smack on the REAR", cause I have the same problem.
의 답변
I am hitting both the end with the monitor/camera and the side were the charger goes, none worked. PLEASE SOMEONE HELP ME!!!
의 답변
의견 추가하세요
worked for me too :D smacked that crap and now the colors are normal :D
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Jake 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 1,543
