89 4x4 toyota pickup
shakes between 50 and 60 mph
좋은 질문 입니까?
charles rodriguez, there could be plenty of reasons. From tires that need to be rotated and balanced, to warped driveshafts, bad shock, bad brakes, bad bearings, worn bushing, worn suspension, worn steering components etc. you will have to start a bit of an investigation. always ask yourself, does it always do that. Start by checking your tires, make sure they are in good shape. Check for worn tread etc. get them balanced. after that work your way through each component.
해당 답변은 도움이 되었습니까?
My check engine light c,e on while i was driving...the motor turned over just fine..just don't start...like im not getting fuel..replaced the efi relay now Im getting fuel...butit still won't start....replaced the igniter coil still no start.....where do i go from here...
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 368
