주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
399 질문 전체 보기
Why won't Dual Drive (1 TB Seagate SSHD) format?
I purchased the dual drive optical bay converter with a 1TB SSHD. All the hardware went into the laptop no problem. I am having an issue formatting the SSHD in the optical bay. I am using Disk Utility on Mac OS X 10.9.4. The drive easily formats to MSDOS and ExFAT formats, but fails when formatting to any Apple formatting system. What am I missing? I tried to use the Seagate drive software, but it is Windows-only. I've also tried partitioning over the current partition. No luck. I can partition to free space with no issue. Just not able to create an Apple Extended format partition.
Disk utility error:
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Try deleting all of the partitions and try again.
Can you give us the model number of the Seagate drive you got.
해당 답변은 도움이 되었습니까?
점수 1
3 댓글:
I have tried deleting all of the partitions to free space but that doesn't work either. Using the erase part of disk utility only works when erasing to MSDOS or ExFAT formats. Here is the link to the drive I bought:
1 TB SSD Hybrid 2.5" Hard Drive
It says that it should be compatible with the model MBP I have.
For clarification, I think the seagate model number is "ST1000LM014" (visible in the close up image on the product page).
This model has an issue with the higher speed SATA HD or SSD in the dual carrier. Here's a note on the issue from OWC Data doubler. The seagate drive you have is a SATA III (6.0Gb/s) while this drive can match to SATA I or SATA II I/O speeds the system is telling the HD it can run at SATA III so you get into a bit of a mess. I am surprised you can create FAT32 or ExFAT partitions with this drive. The older version of this drive could work here as it's I/O is SATA II. OK, what to do? I would try setting up the drive externally to verify things. If it worked that way that proves the issue. The other option here is to swap the drives around if your Apple drive is SATA II, more likely it's SATA III so while it may appear to work you could encounter corruptions.
댓글 달기
귀하의 답변을 추가하세요
Alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,451
