주요 콘텐츠로 건너뛰기
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 질문 전체 보기
Samsung Tab 3 SM-T210 LCD removal and replacement
The glass lens and the LCD screen on my Samsung Tab 3 (SM-T210) has been damaged. I know how to remove the glass lens, there are many tutorials for that, but I cannot find any tutorials on how to remove the LCD and replace it with a new one. Is this repair even possible, or recommended?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
Sorry. I posted my comment in the wrong section. See below
댓글 달기
답변 2개
Ive just done a Galaxy Tab 3 digitizer & LCD replacement. I used a hot water bottle 1/3 filled with fresh boiling water. The reason for it only being 1/3 filled was - if you put too much water in the hot water bottle it almost turns in to an oval shape. So you have less of the bottle touching the surface of the screen. With 1/3 the surface of the bottle remains quite flat, so all of the areas of the screen become heated, softening the glue enough to get a scalpel or other thin sharp object in. Once the digitizer was off it was just a matter of making sure all the peripherals & ribbon cables were disconnected from the logic board. Then place the exposed lcd side of the frame back on to a refilled 1/3 full hot water bottle. I found a small amount of adhesive holding the LCD to the inner frame. Once warmed up enough i then gently pressed the lcd from the inside part of the frame until the complete LCD just popped out.
Installing the LCD & Digitizer was the same but in reverse. Once i was sure all the glass & other bits of crap had gone from the frame i placed the replacement LCD in to the cut out of the frame to be sure if fit then removed it & put a few strips of double sided screen tape in to hold the LCD in place. The other tip i found was to use the double sided tape around the digitizer edge & the inside of the frame where the 2 surfaces would meet. Once the glass was ready to put back on i left both the glass & the frame on the previously mentioned hot water bottle for around 6 or 7 mins. This softened all the adhesive up enough to be able to slide the new digitizer around to get a perfect fit.
After i was happy with the positioning i then reheated the front of the digitizer on another 1/3 full hot water bottle & then clamped the digitizer down with around 15 or 20 clothes pegs. This put just enough equal pressure all around the glass to the frame. Then i left it all to cool down for a couple of hours.
Im rather pleased with the results :-)
Gazza
1/ Heating up the digitizer for gentle removal
2/ Gradually working the digitizer free
3/ Clamping the new digitizer down with clothes pegs while the adhesive cools & hardens
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
how to remove touchscreen
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sams 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 14,849
