Water Damaged in my microsoft zune 30
how do i get water damaged fixed in my zune
좋은 질문 입니까?
Jesse, you will have to disassemble your Zune. Use this guide to remove teh logic board. Clean all the parts with 90+% isopropyl alcohol and a soft brush. You can submerge the board in the alcohol and do not forget to clean all connectors as well. Once you have properly cleaned it, check for any missing or burned looking components, then replace the battery and reassembly your Zune to re-evaluate. Water damage is the hardest to diagnose and to repair. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 255
