주요 콘텐츠로 건너뛰기
Troubleshooting information and disassembly guides for garbage disposals.
5 질문 전체 보기
Kenmore garbage disposal - No sound, just won't turn on
What if you turn on the disposal & there is no sound, no hum? It didn't break down while in use, & I have tried to fix it--pushed button on bottom, checked for blockages, flipped breaker--to no avail. I don't have the right sized allen wrench for the hole in the bottom, but seemed to move around a bit & sound like it's got water in it when I tried another tool in said hole. I want to fix it myself before calling the landlord. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
I finally have the answer, it was a loose wire in the toggle switch housing. No idea why it came loose, vibration must have done it with use. Thank you for your suggestions.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
My Kenmore disposer works (the motor works) but it stopped spinning
댓글 달기
Start Switch
On some models the stopper activates the start switch which is mounted into the upper housing of the garbage disposer. If the disposer won't turn or run at all the switch might be defective. The start switch can be checked for continuity and replaced if necessary.
Other Causes and Conditions
Wall Switch
If the garbage disposer won't turn or run at all the wall switch might be defective.
Non Serviceable Motor
If the garbage disposer won't turn or run at all the motor might be defective. The motor is not replaceable. If the motor is dead the disposer will have to be replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Please tell us what worked.
댓글 달기
답변을 추가하세요
Trace 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 18,877
