주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Why is my iPhone 5's home button rotating?
After dropping my iPhone 5 (CDMA A1429), I broke the digitizer and LCD. After replacing the entire part and reassembling the phone, the home button began to rotate, or feel loose. If I put very light pressure (not clicking) and move my finger to the right or left, the home button will move with it. It will not move very far, but has that loose feeling. Would I just need to also replace the home button, home button ribbon cable, or both? I checked the screws of the plate that holds the home button in place and the gasket is on it. What else can I try? As I am writing this, I noticed as when it rotates, it makes a click sound. If any other information is needed, please ask. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Chances are that the black gasket that sits behind the plastic button itself has lost it's stickiness. This is supposed to stick to the underside of the glass and hold the home button in place.
If it's not sticky anymore, I usually used a little bit of thin double sided tape at opposite corners of the round opening on the inside of the glass (this will then stick the slight plastic ledge on the home button to the screen). Reassemble and test it. If you can't get double sided tape thats thin enough, you can put normal sticky tape on the back end but it might not do much of a good job.
I would avoid using any glue as it can cause major issues and doesn't have much give to it.
Goodluck in your repair endeavors :)
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
This doesn't work. Gg
@duuuude Gonna have to purchase new home then and fit it, easy.
댓글 달기
귀하의 답변을 추가하세요
Conor 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 22,105
