주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Water soaked iPhone 5c won't power up
iPhone battery not showing any voltage. When I plug in the lightning cable, can't read any voltage at the battery connection socket on the charging board.
Questions:
Should the display show the Apple logo when I plug in the lightning cable even though the battery may be dead?
Should I be able to measure voltage at the connection socket on the charging board?
Are there any other test points where I can measure to determine that the charging port board is faulty?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
When iPhone's are plugged into the mains they do not need battery life for them to show the Apple logo, so you should be seeing the Apple logo when it is plugged in. This means that the phone is not recognizing the lightning cable, try a new cable. It is a common fault on all of the iPhone 5 series that the charging ports go I replace too many a day/week so I would suggest just replacing the charging port as it's most likely to be that plus they don't cost too much.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sara not really the case...
First off if it was water damaged did you clean the board for corrosion?
9 times out of ten the battery needed replaced and if battery is dead and is still connected to the battery connecter it will not show and apple logo until the battery is removed from the connector
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks SaraMai and Con.
Tried to power it up with the lightning cable with the battery unplugged, no logo. Was able to test the lightning cable by charging another phone.
Will remove and check the main board for corrosion before installing replacement parts. Have ordered replacement battery and charging port board.
댓글 달기
귀하의 답변을 추가하세요
Tinkerer05 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 176
