iMac은 Apple의 올인원 데스크탑 컴퓨터 라인입니다.
6720 질문 전체 보기
LCD panel remains black
I installed a 250 gig SSD drive and I installed 4 Gigs of memory. After installing the drive ... my front panel no longer lights up..I have checked for loos wires and or connections. I have also tried reversing connections to the LCD panel..Are they polarity orientated? I honestly don't know.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
2개의 답변
선택된 해법
Start over and do one thing at a time. Replace the old hard drive and the old RAM and try to boot. See if the DVD is working, boot from a DVD. Then change the hard drive and clone your system or format the new drive and install a new system. If all is well, go for the RAM, one stick at a time. You tried to do to much without checking each step.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
+ Ralph
의 답변
의견 추가하세요
Check the RAM
seating - any startup beeps or lights?
If this answer is acceptable please return and mark it.
Good Luck,
N
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I found out that one of the Ram modules was corrupting my hard drive. I installed the old drive and my system booted up. I installed my original memory to star and then added one off the upgrade modules. The system recognized that upgrade..I then installed the second memory module, and once again my operating system became corrupted. I re-installed my SSD Drive went back to my original Memory module, and reinstalled the operating system. I believe one of the modules is faulty, and that is what cause my whole problem. With the new memory Modules installed I did not even have my screen powering up...I appreciate the comments and help..If we share our information, we shall be able to conquer all problems..but only if we do it one piece at a time..excellent advice.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Bruce Fallgren 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,195
