주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Two 'broken' iPhones, which way to fix?
Hi. I have two iphone 4. One works 'fine' but the home button does not respond - so we have to use assisstive touch. This iphone is from the day of launch - so has been around for a while! I was recently donated another iphone 4 - much fresher - however - I think this has had water damage (denied by previous owner) - it does turn on - but does not go past the connect to itunes logo even though I have tried DFU mode etc. Google tells me that either the battery has gone or the something power related. So my question is - which way to go! Which iPhone do I use for parts - or which do I fix? Do i take the home button out of one, and merely replace the home button on the older iPhone 4, or what would I take out of the older one to repair the possible water damaged iphone? Any suggestions? Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Hello home button flex will fix one iPhone
The other would be as simple
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks for your reply. Could I ask - what specifically to look to change in the water damaged phone? What components would you attempt to swap or salvage from the older phone to install in the other? I could then look for the specific steps on the ifixit guide and know what tools to purchase. thanks
First thing is to open phone and wash the motherboard with ISO alcohol then leave to dry for 6 hours..
When dry put motherboard in your other iphone 4 because you no all the parts work bar the home button .. And if it turns on then you no motherboard is good before you buy parts that you might not need
댓글 달기
Yeah, and also, if you're looking for cheap, free shipping parts for the future problems, that's ebay.com. I've bought plenty of parts for cheap, and I can bravely say I'm satisfied with them. By the way, I have an iphone 4 and the home button is one of the downsides cuz they brake easily. So as Con said just take the home button from the other one and u should be good!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 27
