주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5 won't activate after factory reset
iPhone 5 suddenly developed the "Searching..." problem (no cell service, only wifi). After researching, I did a backup on iTunes, then restored all factory settings. Now, phone will not activate! Error message is "Could Not Activate iPhone because activation server is temporarily unavailable. Try connecting to iTunes or try again in a few minutes." Have tried dozens of times through iTunes and wifi, even bought new SIM card, still SAME ERROR.
Any ideas? Shows Wi-Fi is connected, and still Searching...Comm board maybe?
Thanks in advance. This site is awesome!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 171
댓글 42개
Well I just opened my phone as i had the same problem an now everything has gone black and it won't shut properly...? Help!
Has anyone found the solution to this problem???
Reset of the phone by holding Home button and Power solved this problem for me.
iPhone 5s ma sim activate Kasy hu gi plz tell me
Unfortunately I forgot my apple id,then one of my cousin reset my iPhone 5,so now how to do, may anyone give me the answer please?
댓글 37개 더보기
댓글 달기
답변 18개
선택된 답변
Hello. Skip to the asterisks for the solution.
Background
I was on vacation in the mountains where I expected to have low signal. I planned to be out mountain biking and wanted to conserve my battery for an emergency. I put my phone on airplane mode for this reason. I turned airplane mode off after completing my trip, but my phone never again obtained a signal. I maintained WiFi access. (Note: I never jail-broke my phone, opened it, I was not using it when this occurred)
I believe my problem is the same as yours, and that the airplane mode was unrelated. It said searching continuously. It still had wifi and worked like an iPod would.
I spoke to Apple support on the phone and they said connection issues were a Verizon problem, not an Apple problem and to go to Verizon. That option was not available to me, so without success, I attempted the following...
- Turn off with power button
- Force restart (power and home held)
- Reset network settings
- remove SIM card, blow out (both powered on and off)
- Downloaded most recent iOS but it failed to install (iOS 8.2)
None of these interventions changed my situation.
I went without a phone for the rest of the week, then visited Verizon upon returning home. They did the same things I did, but they also tried another SIM card and did a factory reset.
However, this completely locked down my phone on the activation screen, failing each time. It would still not find a cellular signal. It would not activate with WiFi. It also did not activate with iTunes when I got home. Verizon told me to go to the Apple store.
It took a few days to get an appointment at Apple. I spoke to a "Genius" for about 10 minutes, during which time they restarted the phone, tried another SIM card, and told me it was out of warranty. They gave me the following options...
- Exchange it $249
- Sign a contract for a iPhone 6 $200
- Buy a new phone outright ~$700
I told them I would sleep on it.
I refused to accept that my iPhone was now a paper weight. Worst case, if it were a damaged cellular card, it should as a minimum continue working as a wifi iPod.
A lot of research, trial and error was done when I got home.
The following is the solution.
Here are the steps I took to solve this problem (to the best of my ability to explain them)
- Turn off iPhone
- Open iTunes on computer
- Hold down home button on iPhone and plug iPhone USB into computer
-> (Do not plug in USB before holding down the home key)
- Click restore iPhone on iTunes and update when asked.
-> (You want a full software replacement with update)
This was clearly caused by some sort of corruption to the firmware.
Outro
I am very disappointed that Apple so quickly wrote me off. This problem was clearly caused by a bug in software/firmware. I was not operating or abusing the phone when it failed, nor has it ever been jail-broken, or any other kind of abuse.
Apple passed the buck right out of the gate. My wife's phone was clearly working and mine failed, yet they refused to provide any assistance. This problem could have been resolved immediately with the PC we had (same PC used to later fix the problem).
Apple's "Genius" also wrote me off. I understand that I have had my phone for 2.5 years and I am outside of the warranty window. However, this problem is clearly a software, and possibly iOS problem that Apple should take responsibility for. Telling me to spend hundreds replace a perfectly working device is terrible customer service. I am glad I spent a few hours researching this problem and solving it myself, but I am very disappointed that it could have been resolved in a few short minutes by an Apple tech. It also was about a 2.5 hour total time involved in the Apple store once my commute is included.
I hope this story makes it to someone important at apple, and I hope none of you had to or have to spend hundreds to replace a functioning device.
I do not have any special tech background. Just GOOGLE and determination.
해당 답변은 도움이 되었습니까?
점수 93
댓글 60개:
Thanks a lot - this solution actually worked. Had to to a factory reset in our case, but still it is better than replacing the phone.
many thanks, it worked for me like a charm
Have same problem .... my phone have "searching..." after claim battery.
And now ... can't activate
Ru5ty's solution worked!! Came back from a trip to America and my phone was stuck on searching. I backed up to itunes. Would not let me restore because I couldn't activate. Apple forum / support a complete joke.
I don't know how Ru5ty came up with the idea to carry out the steps he did...seems to be no logic to it. But I am back with my mobile carrier, everything restored and phone working. Like Ru5ty says, all the want is for you to pay hundreds of pounds more for a completely unecessary new phone.
Thanks Ru5ty.
Thanks so much, sadly I found this article after splashing out on an iPhone 6, now I can sell my iPhone 5 as second hand in working condition, thanks again. Matt
댓글 55개 더보기
댓글 달기
I have managed to fix mine by getting the solution from another issue and trying it with this.
1. Switch the phone off, leave the sim card in and put inside a zip seal sandwich bag. (I put in inside another one for extra protection from moisture).
2. Put it in the freezer for 45-60 mins. (really, the phone won't break).
3. Take it out of the freezer and the bags and switch it on.
4. Try to activate again, the message might come up again, but this time it let me bypass it.
5. Get to the home screen as fast as possible so ignore any apple sign in requests.
6. When you get to the home screen. Switch the phone off, wipe off the condensation and put place somewhere warm for an hour so there will be no water damage.
It worked for me.
Your "searching problem" will probably be fixed by replacing the antenna.
해당 답변은 도움이 되었습니까?
점수 12
댓글 9개:
I tried this, combined with the steps ru5ty03 offered, and fixed the "Searching" problem. Neither method on its own worked. But in combination, it worked on the second try. One of the many mysteries of life. Thanks for the great info!
This is a good temporary solution to just get your iphone activated, but won't fix the underlying faulty baseband chip.
This is exactly
BS
1.... I'm not doing that 2.... I'm not doing that and 3... IM NOT DOING THAT. I'm not gonna ruin my phone
can someone actually verify this pls
댓글 4개 더보기
댓글 달기
This has worked for me. (At least I was able to activate, I still have "Searching..." problem)
1. Hard reset the iphone. (Home+Power buttons until apple sign appears.)
2. Switch off the iphone
3. Put the iphone into freezer for 1.5 hour. (Your sim card should be inside)
4. Wipe the moisture of iphone and wait half an hour
5. Wipe the moisture of iphone again and try.
해당 답변은 도움이 되었습니까?
점수 6
댓글 5개:
Thanks, this worked for me!
Didn't work for me.. no change .. still won't update.
how to setup my iphone? i cant setup bcause of apple id. im not the original owner of this iphone.. i actually ask the apple id and pass to the owner but he told me that he forgot the apple id and passwors.. how can i solve it.. pls help me
I had been trying to get past the screen " Could Not Activate iPhone because activation server is temporarily unavailable. Try connecting to iTunes or try again in a few minutes." I tried following your suggestion ...I did not believe it would work ....how wrong was I ???!!!! What a brilliant solution !!! Thankyou for giving me back a working phone.
Just done this with a iPhone 3GS and I kid you not it bloody worked lol
댓글 달기
check first your imei is there if not you cant activate please give base band 15s heat and also resold sim reader interface after everything will be ok best of luck asad
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
huh?? I HAVE NO IMEI?? WHAT DO U MEAN?
Neal, I have the same problem .. iPhone 5C, shows NO IMEI and it won't let me restore or update the iOS. It was working before I tried to restore it!
Hi have u fixed it? I have the same problem :(
its a baseband chip fault, probably due to the solder cracking and the chip no longer making good contact with the board, needs reflowing (heating the chip so the solder melts again and makes contact), or the chip needs removing and new solder applying, which isn't an easy task
댓글 달기
Just follow the below mentioned simple steps, if you wish to activate the iPhone:
-First insert the activated as well as the compatible SIM Card (for iPhone 3GS) or the micro-SIM Card (for iPhone 4 as well as iPhone 4S) into the device.
-To Switch On your iPhone, press and hold the On/Off button just for few seconds. After that carefully follow all the instructions which are there onscreen in order to activate as well as to set up the device.
-And you can also use the option of using ‘iTunes’ to finish your activation.
-Just connect your iPhone device to a USB 2.0 port on your PC or Mac via the USB Cable or the Dock Connector which comes with the device. ‘iTunes’ will automatically open-up.
-After that, carefully follow all the instructions which are there onscreen in the ‘iTunes’.
-Now to use ‘iTunes’, just ensure that your PC is linked with the internet while you activate your device, either via any direct connection or a Wi-Fi network to the router or your Ethernet network.
-And in case it’s not linked with internet, you won’t be able to activate your device successfully.
If after following the above steps your iphone still not get activated then you call Apple Customers Services here.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have tried all of that, and it is still stuck on "Connect to iTunes". Apple Support says it is equipment failure since there is no IMEI listed on the phone, which indicates baseband failure. I think the phone was Jail Broken which caused the problem .. there is no sign of water damage. The freezer trick mentioned above did not work, but Apple says one of their service centers may be able to recover the phone but for a fee that is as much as I bought it for, so I'm returning it to the seller. I have learned when to give up and "cut my losses". Thanks anyway for the advice, but I have tried all of those things with no results.
댓글 달기
After 4 weeks of having the phone turned off I finally was able to update it and it is finally working!
I had exactly the same issue of "Searching", then reset everything from factory, then I was not able to use it cause it got stucked in the Hello white screen. Tried also the software update with iTunes but it showed error message, something about servers not being available. I tried that with 2 different macs (both with latest itunes version) and the same issue... But until this week I updated to OSX EL CAPITAN and updated the iphone through iTunes without an issue !!!. The installation was flawless and the celluar signal came back. My iphone 5s is working in great condition now. I was so close to sell the phone as scrap. Please, before doing anything radical try updating to El Capitan or at least to use iTunes from a mac with El Capitan to update the firmware of the iphone. I hope this helps somebody out there.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i had this problem for two hours, then i removed the sim card slot and tried, it worked 3 times in a row, hope this helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
It sure did help. I tried this and it worked. I had been unable to activate my iPhone after doing a restore. I spent many hours on the phone with technical support,searching the internet, restoring again and trying to activate again and again. Nothing worked--until I tried this suggestion. Thanks very much, Adam.
댓글 달기
Well, this is a common issue after restoring to factory default. You can use a third party tool to help to enter the safe mode of iPhone 5 and then just repair this problem. Just refer to How to Get iPhone/iPad/iPod in or out of Recovery Mode with iOSBoot Genius
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hello, I have the similar problem as you. I'm having an iPhone 5s, with iOS 11.1 (if I'm not mistaken). Recently, I have updated to iOS 11.3 through iTunes restoration but still unable to pass through the activation SIM stage. When I insert my SIM card, it shows:
"Your iPhone could not be activated because the activation server cannot be reached. Try connecting your iPhone to iTunes to activate it" - the message pops up in iPhone
"The iPhone could not be activated because the activation information could not be obtained from the device. Disconnect your iPhone, make sure the SIM card is inserted correctly." - the message pops up in iTunes
I have had tried countless times to restore it through iTunes and it seems like the problem still persist.
Anyone have any solutions so far?
Any reply would be greatly appreciated.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Wish I had read this before I went and bought a new phone
my I phone is still not activating
I'm facing slimier problem from past 2 months
댓글 달기
For anyone reading this thread: If you tried all of the above, as I did, This is what was wrong with mine: DEAD SIM CARD.
I went to the Verizon store, Dead SIM card, FREE, repair. Please check in to that before you do a full phone restore. Luckily, We didn't lose anything as we backed up via iTunes...but it was all unnecessary step in the end.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
found this page which has solved this for me. Holding the two buttons together until after the apple logo has shown, continue to hold until a connect to itunes logo has appeared, connect the iphone to itunes and then a message will appear, i had to choose the resstore option to get it to work. it took awhile but my
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Okay, So you have to follow this piece by piece.
1. First try to remove then replace the sim card
2. then you go to your settings (if the sim doesn't work)
3. Click Carrier (will be a green phone)
4. If it is set to manual, make sure you flick the switch to make it automatic.
5. if this doesn't work then try resetting the phone again.
Let me know how this works,
Keegan
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
ok, um one thing.... You see, our phones are stuck on the activate page, meaning we have NO way of getting INTO our phones to go into our settings, which means... WE CANNOT GO TO THE SETTINGS!!! :D ._.
댓글 달기
Have you tried disconnecting the battery, and let it set unplugged for a few minutes. Then restarting it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
that is because of IMEI ! ( Baseband CPU/PMU) has problems either reball or use ACT tool to fix it
regards
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Alright I just resolved the problem with my iPhone 5 a few days ago. It hasn't been working for close to 3 weeks with the infinite "searching..."
1.Soft Reset your phone. If that doesn't work,
2. Remove SIM card
3. Restart phone (if it still says searching while SIM is removed skip to step 6)
4. Reinsert SIM and turn the phone on (still not working?)
5. Update iOS.. Yes I know it sounds so predictable, but it has helped in the past.
6. If all else fails, grab a charger and use the "Restore" feature on iTunes. After repeating step 6 twice, my phone started to pick up cellular service again allowing me to complete setup.
Best of luck :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try after 3 days later
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Make sure you have a working data connection, whether it is cellular or wifi, otherwise it cannot contact the server.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i have... but still not working
댓글 달기
My Iphone 7 Plus failed to activate after IOS 13 update, apple said it couldn’t be fixed and wanted £300 to repair it.
But I downloaded IMyFone Fixppo cost £30 but solved my problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Roslyn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 30
30일 전: 111
전체 시간: 269,176
