주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
질문 마감됨
Does this model's keyboard replacement also work on a mid-2012 model?
I have a Macbook Pro mid 2012 and i'd like to replace its keyboard; however, there's no guide for it, all I can find is this one. I was wondering if perchance it would be the same?
Thanks in advance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sadly, Apple does not sell the keyboard alone. The newer models also have a mix of screws and snap rivets (aprox 50) so its a bit of work just to take it out.
Some people have managed to locate the manufacture of the keyboard in China and have imported the keyboard part alone.
Frankly, I recommend just replacing the full upper case Vs fighting with the screws let alone having to tap out the holes of the rivets you break for screws which you then need to locate to fit the tight space. If you don't replace the rivets your keyboard will feel very spongy as it sinks as you type.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 114
