주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
질문 마감됨
Only charging to 12-19%
Hello
I have recently repaired a customers iPhone 5S by installing a new charge port flex due to you having to wiggle the charge cable to get it to work.
I fully charged the device to 100% battery as did the customer successfully for the next couple of days after the repair.
Over the last few days the customer has stated that the phone will only now charge between 12-19% and then stop. Apparently the charge symbol is displayed on the screen
Has anyone any ideas as to what might be causing this or has anyone else suffered a similar problem? The customer is returning the phone next week so I would like a few ideas to try.
Many thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
99% of the cases which I get like this are from a bad battery. I'd start there. :)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I thought it may be and I intended on testing a new battery when I get it in next week. I just found this a little coincidental as I have only just replaced the charge flex and it appeared to charge ok the first couple of times.
Maybe where the customer has needed the repair for a while the battery was not getting complete charging cycles due to having to hold the charger at a certain angle. Maybe this has caused the issue with the battery to develop.
Thank you
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 132
