Digitizer not working after replacement (some is)
I replaced a digitizer with a cracked glass mainly in the top left (next to camera). Everything seemed to go well. Removed the old digitizer, then the lcd (being careful). Once i got it back together the new digitizer looking at it with the home button closest to you and the camera on top... well the top from left to right about one inch down will not work from touching it. Which making the top most icons inaccessible to touch.
faulty digitizer screen maybe?
Is there ways around this?
Thanks.
Bill
좋은 질문 입니까?
댓글 1개
I had the same problem (bad digitizer but no broken glass) - it did not fix the original issue - the touch keypad works intermittently. I used an IFIXIT kit - they sent the wrong color (black instead of white -used it anyway) and their replacement home button does not work at all - had to throw out everything and go back to the mess I had to start with - I won't do business with IFIXIT again.
Steve Smith 의
