주요 콘텐츠로 건너뛰기
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
L button stuck and won't spring back up
i dropped it on the stairs and it took two hits the the L-button and now it is stuck and won't spring back up when i press it. i have tried blowing on it. i tried putting like a little greese to make it slippery and sping back up, but nothing is working please help me
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
please don't say blow on it. cause it doesn't frkin work
댓글 달기
답변 1개
선택된 해법
Most likely when it hit the floor it actually bent the piece of plastic that surrounds the button. The best way to fix this is to take it apart and try to carefully bend that piece of plastic that the button rubs on back a little.
I have even fixed this problem by taking a hobby knife and shaving off a small bit of the plastic that it gets hung up on. This worked well.
I don't know how stuck it is or whether you can even fix it without putting a new lower case on but these are the things that have worked for me.
It's also possible that there are some other things going on internally that are causing the problem.
I hope this helps.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
yes thank you i took a pocket knife and just was picking at it and got a little piece out and it's not as bad as it was, but it's do able
댓글 달기
답변을 추가하세요
JakeJ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 4,347
