How much transmission fluid for a Harley-Davidson Sportster?
How much many bottles of transmission fluid do I need to use? Please
좋은 질문 입니까?
좋은 질문 입니까?
Here's a link to the owner's manual which says: "Add 1.00 U.S. qt 0.95 L of GENUINE Harley-Davidson FORMULA+ TRANSMISSION AND PRIMARY CHAINCASE LUBRICANT (Part No. 98851-05 qt) through clutch inspection cover opening until the lubricant reaches the bottom of clutch diaphragm spring." under the "Changing Lubricant" section.
해당 답변은 도움이 되었습니까?
Trina,
The Sportster should take around 25-30 oz. You should check with your service manual to make sure. Otherwise you can also call in a local Harley shop and inquire.
Best of luck!
해당 답변은 도움이 되었습니까?
Sorry, forgot to mention that its somewhere between that amount because it depends on the year of your sportster. You can start with 1 bottle or 1Qt. and then work from there.
I got my Harley Sportster service manual from TheManualStore.com. I use it ALL THE TIME.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,385
