주요 콘텐츠로 건너뛰기
iPad 2세대, Wi-Fi, GSM 그리고 CDMA 모델이 있습니다. iPad 3 출시 전에 일부 모델을 새롭게 하였습니다. 수리는 어렵고 열과 비집기가 필요합니다.
730 질문 전체 보기
Dropped my Ipad and now my touchscreen isn't working right
I recently dropped my iPad 2, and at first it was fine. Then, I noticed the touchscreen kept freaking out as if I were scrolling it left to right continuously. Eventually, it started clicking on things by itself and now I am unable to even click from the middle of the iPad all the way to the left. The panel is cracked pretty bad at the top of the device, could that be why my touchscreen is malfunctioning? Or is it something else?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
Sounds like you need a new digitiser. That sould solve your problem. Plenty of tutorials for it if you want to tackel it yourself, just take your time. :)
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thank you for your help! I looked it up and it sounds like that's the problem to me too.
댓글 달기
Chances are there is also a dent in the case of the iPad. The odd behavior you are describing is ghost touches on the screen. Unfortunately its nothing cool like a poltergeist has possessed your tablet and you will now be able to move objects with it. It just means that something is pressing up on the screen, causing the digitizer to misbehave.
Luckily its a very simple repair. I highly recommend taking it to a reputable local repair shop to have the repair done. It will take them no time and your iPad will be as good as new.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
well ghost touches are impossible as the ipad is supported with heat as touches well y know what i mean
댓글 달기
You know this is illegal to carry a cracked ipad, because apple doesnt want to look bad.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
how does it make apple look bad? its the buyers fault
댓글 달기
귀하의 답변을 추가하세요
Kelsey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 1,985
