주요 콘텐츠로 건너뛰기
The Cuisinart Mini-Prep Plus DLC-2A is a compact food processor that has been in production since 2001 and retails for about $40.00.
Why isn't my Mini-Prep Plus turning on?
The chopper is not responsive when the chop or grind buttons are pressed.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
I've only used this machine a couple of times and it worked perfectly. Went to use it today and no response. I've done all the trouble shooting tips.
댓글 달기
답변 2개
가장 유용한 답변
Also, ensure the plastic tab of the bowl cover locks into the slot on the back of the machine. This will short the safety switch.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thank you so much.
Saved me buying a new one.
Philomena
Bought mine at a yard sale and had no idea. This was the fix. Thank you.
댓글 달기
Check and ensure that power cord is plugged in. If the power cord is plugged into a working power outlet and there is food inside the workbowl, try removing some of the contents and attempt use again. Failure to "turn on" may be caused by overloading the workbowl to a point where the contents prevent the motor from functioning properly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nancy deGorter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 45
전체 시간: 6,635
